08-10-2021 07:50 AM - edited 08-11-2021 01:49 AM
Cisco aironet 1815i (AIR-AP1815I-D-K9C) shows blinking red led after configuration.
unboxed and connected the AP through SSID “Cisco AirProvision” and configured the AP with Mobility Express setup. After rebooting the AP shows blinking red led.
Ap connected and powered up through Cisco Catalyst 9200 Series (C9200L-24P-4G-E) poe switch.
Connected in wireless vlan access port.
Changed the port on switch and ethernet cable . no luck
any suggestion ?
Boot process is attached.
Thanks in advance...
08-10-2021 09:43 AM
- Post complete boot process of the ap , and check the switch logs too
M.
08-11-2021 01:47 AM
08-10-2021 03:29 PM
Contact Cisco TAC and get the AP RMA-ed. It is dead if the red LED is flashing.
08-11-2021 01:54 AM
Thanks Leo for your response.. but blinking red led means Ethernet link is not operational. The AP is not dead and I can login through console.
www.cisco.com/c/en/us/td/docs/wireless/access_point/1815/quick/guide/ap1815igetstart.html
08-11-2021 02:16 AM
If you have access to console, post the entire boot-up process.
08-11-2021 03:22 AM
08-11-2021 03:35 AM
>...Ethernet link is not operational...
For these kind of issues , you may for instance at the switch-side configure the particular interface with logging event link-status, then check the logs as the ap is booting , also issue show interface status command, and last but not least look at interface counters, watch for errors if any.
M.
08-11-2021 04:47 AM
@marce1000 wrote:
[08/10/2021 12:01:12.5599] ess_edma c080000.edma: wired0: GMAC Link is up with phy_speed=1000
Nothing wrong with the link. The ethernet port has successfully negotiated to 1 Gbps.
08-11-2021 05:48 AM - edited 08-11-2021 09:14 AM
Hello Leo ,
I have purchased total 20 Access Points, same model (AIR-AP1815I-D-K9C).
Today I tried to configure another AP and ended up with same result.
I tried again and configured a third AP and it worked. Now the AP is working as a controller and also broadcasts ssid.
Now the user can connect and surf the internet through the AP. I still don't understand why the previous two AP's don't work.
I have attached the boot process of the working AP . Please check and let me know if you find any appropriate reason for the problem.
Thanks in advance..
08-11-2021 05:42 AM - edited 08-11-2021 09:15 AM
Hello marce1000 , I have purchased total 20 Access Points, same model (AIR-AP1815I-D-K9C).
Thanks in advance..
