Cisco Aironet 1815i/WLC3504 with Cisco ISE 2.2
edwardwaithaka
Is Cisco Aironet 1815i with WLC3504 supported with Cisco ISE 2.2?
Any issues to look out for with the setup?
Ric Beeching
Level 7
Level 7
Yes it is just be aware 1815 must be in LW/CAPWAP mode and the 3504 must be running software 8.3.112.0 minimum. I recommend 8.5.140.0.
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#wp99531
Ric
Please rate helpful / correct posts
Yes they are both supported.
For future reference bookmark the Cisco Wireless Compatibility Matrix:
For the controller code to run look at the TAC recommended versions:
https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html
Reference ISE 2.2:
Yes will work for CWA, RADIUS with that controller
*****Help out other by using the rating system and marking answered questions as "Answered"*****
