Cisco Aironet 3700 Series IP connection
undercover921
So I have Aironet 3700 devices and I can connect to the Cisco WLAN Controller with the IP address to manage the AP devices. I was wondering if I can connect to the AP device itself if I have the IP address of the AP device.
xploit007
Yes, you sure  can. Steps:
1. Setup the Login Cerdentials under the 'Global Configuration' under the  'Wireless" Menu.
2. Enable 'SSH' for the AP is question, on the 'Advanced' page under the AP in question.
      a) Click on the AP in question from teh list of AP on the 'Wireless' Page
      b) Go to the 'Advanced' meun
      c) Check the teh box next to 'SSH' or 'Telnet'
See the attached screenshots
5 Replies 5
H
You can. Considering you have connectivity with the AP.
 Go to the AP configuration on the WLC and config a credential for ssh or telnet.
-If I helped you somehow, please, rate it as useful.-
So the AP doesn't have a GUI interface then that I would just type IP on browser and goto as the WLC.
So the AP unit doesn't have a GUI interface then that I would just type IP on browser and goto as the WLC.
Web interface only with autonomous AP. Lightweight only permit ssh or telnet with a limited amount of commands.
xploit007
