ā10-25-2017 02:27 AM - edited ā07-05-2021 07:45 AM
I have Cisco WLC 2504 which has 10 AP 1852E joined , i installed license 5 AP successfully , when i add new Access point AP 1852E is not joined to WLC it takes IP address from same scope of 10 AP i access to this AP and i see this error
[*04/11/2017 05:08:35.2474] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*04/11/2017 05:08:44.7544] CAPWAP State: Discovery
and you can see the full debug file and show in the attached file.
Solved! Go to Solution.
ā10-25-2017 04:06 AM - edited ā10-25-2017 04:07 AM
#capwap ap primary-base 10.100.82.10
The command is: capwap ap primary-base 10.100.82.10 DC1-R15-WLC-01
ā10-25-2017 02:40 AM
ā10-25-2017 03:18 AM
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.2.151.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.101.1
Firmware Version................................. PIC 20.0
Build Type....................................... DATA + WPS
System Name...................................... DC1-R15-WLC-01
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 10.100.82.10
IPv6 Address..................................... ::
Last Reset....................................... Software reset
System Up Time................................... 0 days 20 hrs 14 mins 45 secs
System Timezone Location......................... (GMT +3:00) Baghdad
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
--More-- or (q)uit
Configured Country............................... SA - Saudi Arabia
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +31 C
External Temperature............................. +35 C
Fan Status....................................... 3500 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 5
Number of Active Clients......................... 17
Burned-in MAC Address............................ 00:42:5A:55:A9:60
Maximum number of APs supported.................. 75
System Nas-Id.................................... DC1-R15-WLC-01
WLC MIC Certificate Types........................ SHA1/SHA2
Cisco Controller) >show time
Time............................................. Wed Oct 25 13:18:25 2017
Timezone delta................................... 0:0
Timezone location................................ (GMT +3:00) Baghdad
NTP Servers
NTP Polling Interval......................... 600
Index NTP Key Index NTP Server Status NTP Msg Auth Status
1 0 Not Sync hed AUTH DISABLED
2 0 172.20.1.1 In Sync AUTH DISABLED
3 0 172.20.1.2 Not Sync hed AUTH DISABLED
ā10-25-2017 03:42 AM - edited ā10-25-2017 03:43 AM
Are the AP and WLC in same subnet ?
If not then did you configure a method to register an AP to WLC . Example:Option 43
Also try Static config on AP:
#capwap ap ip address <IP> <MASK>
#capwap ap ip default-gateway <GATEWAY>
#capwap ap controller ip <WLC-IP ADD>
Dont forget to rate helpful posts
ā10-25-2017 04:53 AM
Great! thank you It is solved by this command.
