Cisco and MS PEAP Supplicant simultaneously?
michael.kopp
if you install Cisco PEAP supplicant , the MS Supplicant with MSCHAPv2 support will disabled and only Cisco PEAP-GTC is available.
Is there any possibility to have both versions available at the same time , so i can select which PEAP method I`d like to use ?
If not, is Cisco planing to change their supplicant so that it can be integrated with MS PEAP supplicant
regards
Michael
sbilgi
Level 5
Level 5
I don't think this is currently supported, for future support better contact your nearest Cisco reseller for a clearer picture.
