Cisco AP 1121 - repeater mode
Matej G
HI!
Can Cisco AP 1121 act as repeater?
Yes it can.
But my question is - can I use this AP to connect to a wireless network via wireless, and then connect my PC to this AP, so I can access internet?
I hope you understand my question.
(I attached a picture).
Encryption used is WPA.
Please advise!
Thanks!
5 Replies 5
Matej G
No ideas?
Hi gololicic,
You should be able to configure your access point to a be what's called a workgroup bridge. If you're using the web interface to configure the AP, it will be an option under "role in the radio network" on the Radio configuration page.
Give that a try and see if it works!
Hi!
Thank you on your reply.
I will try and report.
Hi!
This seems to be working.
But can you now please help me on configuring security parametres?
The encryption used is WPA. Now I have to set a password and WPA server IP?
Hi!
I cannot pair my AccessPoint with the router.
What can I do?
