Cisco AP 1200 Not Booting
vsawant79
Hello, I am having Cisco AIR-AP1220B Series AP. It is not booting. It gives following message while booting
Testing DRAM...
(press <esc> to bypass)
DRAM OK
Power-on reset.
Copyright 1996-2000 Cisco Systems, Inc.
Copyright 1984-2000 Wind River Systems, Inc.
System ID: 000BBE6D8CA8
Motherboard: IBM405 200MHz, 8192KB FLASH, 16384KB DRAM, Revision 04
Bootstrap Ver. 1.00: FLASH, CRC 1C914641 (OK)
Initialization: OK
and halts.
All the three LED remains Green.
If I press Mode button and then power on this AP then also it does not go to any other prompt.
Is there any way to recover this AP?
Thanks & Regards
Vinay Sawant
0 Replies 0
