Cisco AP 2700-Interface and Drops
I have deployed my Cisco 2700 as a Flexconnect AP with WLC 7.6.120.0 code.
The cisco 2700 AP showing two interfaces, gig 0/0 is up and gi 0/1 is down.
my question is what is this g0/1? as i see alot of traffic on this interface even if its down.
Secondly, in gi0/0 i seeing alot of packet drops and interface reset happening. which might be affecting my Piwis testers as sometimes its loses connectivity.
Need your help to diagnose the problem.
Thanks & Regards,
Nitesh
Rasika Nayanajith
Refer this for Auxiliary ethernet port of 2700 AP. This is used to connect any PoE device
http://www.cisco.com/c/en/us/td/docs/wireless/technology/apdeploy/8-0/Cisco_Aironet_3700AP.html#pgfId-124333
You have to use 8.0.x code to  in  order to use it with different vlan that to AP management
What switch model are you using ?
Rasika
*** Pls rate all useful responses ****
