09-30-2022 12:33 PM - edited 09-30-2022 03:43 PM
Hello
I trying to join the CISCO AP air-cap1602I-E-K9 to vWLC without success
i have this message on the AP
*Sep 30 19:31:52.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.1.1.100:5246
*Sep 30 19:31:53.003: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Sep 30 19:31:53.007: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Sep 30 19:31:53.007: %CAPWAP-3-ERRORLOG: Failed to load configuration from flash. Resetting to default config
*Sep 30 19:31:53.023: %CAPWAP-3-ERRORLOG: Dropping dtls packet since session is not established. 10.1.1.100, 147E, 10.1.1.105, AAD6, 0
*Sep 30 19:32:03.023: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Sep 30 19:32:03.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.1.1.100 peer_port: 5246
*Sep 30 19:32:03.323: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.1.1.100 peer_port: 5246
*Sep 30 19:32:03.323: %CAPWAP-5-SENDJOIN: sending Join Request to 10.1.1.100
*Sep 30 19:32:08.323: %CAPWAP-5-SENDJOIN: sending Join Request to 10.1.1.100
logging facility kern
% Invalid input detected at '^' marker.
logging trap emergencies
Show version on AP
APc067.afca.ad5d#show version
Cisco IOS Software, C1600 Software (AP1G2-RCVK9W8-M), Version 15.2(4)JA1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Tue 30-Jul-13 23:41 by prod_rel_team
ROM: Bootstrap program is C1600 boot loader
BOOTLDR: C1600 Boot Loader (AP1G2-BOOT-M) LoaderVersion 15.2(2)JAX, RELEASE SOFTWARE (fc1)
APc067.afca.ad5d uptime is 25 minutes
System image file is "flash:/ap1g2-rcvk9w8-mx/ap1g2-rcvk9w8-mx"
Last reload reason:
cisco AIR-CAP1602I-E-K9 (PowerPC) processor (revision B0) with 98294K/32768K bytes of memory.
Processor board ID FGL1739S76K
PowerPC CPU at 533Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 7.5.1.73
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
show sysinfo on vWLC
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.5.161.0
RTOS Version..................................... 8.5.161.0
Bootloader Version............................... 8.5.1.85
Emergency Image Version.......................... 8.5.161.0
OUI File Last Update Time........................ Sun Sep 07 10:44:07 IST 2014
Build Type....................................... DATA + WPS
System Name...................................... Cisco_2c:74:2f
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1631
IP Address....................................... 10.1.1.100
IPv6 Address..................................... ::
System Up Time................................... 0 days 1 hrs 7 mins 25 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
--More-- or (q)uit
Configured Country............................... FR - France
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
OUI Classification Failure Count................. 0
Memory Current Usage............................. 60
Memory Average Usage............................. 60
CPU Current Usage................................ 0
CPU Average Usage................................ 0
Flash Type....................................... Compact Flash Card
Flash Size....................................... 1073741824
Burned-in MAC Address............................ 00:0C:29:2C:74:2F
Maximum number of APs supported.................. 200
System Nas-Id....................................
WLC MIC Certificate Types........................ SHA1
Licensing Type................................... RTU
Solved! Go to Solution.
09-30-2022 10:38 PM
- WLC GUI>>Secuirty>>AAA>AP policies>>Add> ? (AP mac addr) and check if it joins.
M.
09-30-2022 10:38 PM
M.
