Cisco Ap console connection issue through Usb-serial converter
I'am trying to connect to AP-1042N console port using a Usb serial converter.
I can connect to one cisco 2950 switch with the same usb serial converter.
I can connect the AP directly to a desktop serial port without the serial usb converter
The usb-serial converter works fine qith routers switches, but the ciso AP.
Is there a known issue with the AP console port with the usb-serial converter?
32 Replies 32
msamighersheen
Facing this issue on 1142 and 2802
JoseRafael2890
I have the same problem already tested 3 cables one with FTDI and I was not successful!
I tried variuous USB to serial convertors the only one that worked was a prolific one.
