Cisco Ap console connection issue through Usb-serial converter
I'am trying to connect to AP-1042N console port using a Usb serial converter.
I can connect to one cisco 2950 switch with the same usb serial converter.
I can connect the AP directly to a desktop serial port without the serial usb converter
The usb-serial converter works fine qith routers switches, but the ciso AP.
Is there a known issue with the AP console port with the usb-serial converter?
32 Replies 32
Stephen Rodriguez
I use a USB-serial all the time and it works like a champ. One thing to check, make sure flow control is set to off.
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Thanks I,ll check it
Have the same problem, I can console into routers fine, but access point 3702 doesn't respond on the console. I have usb-to-serial cable. Did anyone here figured out the problem?
Having the same problem - as per the advice here I've now tried three different kinds of USB-serial cables with no result. Can connect to routers and switches just fine.
I'm using SecureCRT, but also tried Putty - no result.
Very, very annoying.
AP's are different as you need to make sure your setting is 9600 8-N-1.  Many here have stated that they too can connect to a router and switch, but really doesn't mean you can connect to an AP.  Sorry you are having such bad luck. Once I find a good console cable, I pretty much don't use any other.
-Scott
-Scott
Routers and switches are also 9600 8N1.. seems to be something extra the AP is expecting from the serial interface. Three different cables I have all have the issue.
Use the right cable is the right answer - but without knowing which ones work ordering online is just rolling the dice. I could buy another three and still be unable to talk to the AP...
Well it's either you have a bad AP, a bad console cable or a finicky setting.  I have used these:
Gopala 6 FT(1.8M) Cisco Console Cable with FTDI Chip , Usb to Rj45 cable
GetConsole and others make a cable with the FTDI Chip and it's an all in one.
If you can't access a few AP's then you can isolate the issue to the console cable.  However if you can access other Cisco AP's and not one, then it's a bad AP.
-Scott
-Scott
George Stefanick
Sounds like the console settings on the ap may have been changed .. Did you reset the ap back to factory ?
It Is an out of the box ap
It was a rs232 -usb cable issue
The settings in your terminal program need to be 9600/none/8/1 and flow controll off/none.
HTH,
Steve
HTH,
Steve
I have the same USB to serial convertor cable as I dont have a serial port on my laptop. Using this I am not able to console Cisco access points. I have tried on Cisco Aironet 1100 & 1200 series Access points yet.
But with the same cable, I am able to console into Cisco Switches and routers.
Keeping settings like Stephen Rodriguez suggested above also does not work.
If I use the console cable through my PC which has an inbuilt serial port, it works like a charm with same settings. I replaced the USB-Serial adapter but still the problem remains the same. Baffo Adapter image attached.
I will appreciate if someone has figured out the solution. The problem still persists.
Scott Fella
I have never used that. This is what I have used forever and I have had no issues at all. I have used this on windows and macs.
http://www.cablestogo.com/product/26886
-Scott
abhisgu2
Hi Esteban,  Did you get a fix to this problem ?  It seems even 4 years later this issue still persists.
I am using a usb to serial converter but its not working with the AP, but works great with other switches and routers.
Let me know if you got a workaround or a fix to this issue.
Abhishek
