i have a strange problem here...
i live in a etsi regulated country and purchased a cisco's air-pcm350 series
100mw (configurable,internal antenna) air-pcm352 pcmcia adapter,no problem
wheter its working in 100mw or 50mw.this is ok
i have also cisco's air-ap350 access point(ver:c350-k9w7-mx.122-15.JA) i opened it and took the
air-lmc350 pcmcia adapter out the problem is lmc350 is working in 50mw mode
max,it exactly the same pcmcia factor with pcm350 which can operate in
100mw. how can i raise the lmc-350 adapter to 100mw i tried everything with
firmware issues but got no answer.
and note that the 100mw pcmcia pcm-350 (internal ant) made in taiwan, 50mw
pcmcia lmc350 (have two mmcx connectors no internal antenna) made in
singapore.
Anyone knows how to raise the lmc350 pcmcia to 100mw?
thx
