Cisco autonomous assign ip to wired client
bikoo106
Hello
i have the below setup, i need to know how to let the wired clients get ip form Cisco AP DHCP.
ISP Router  >>> 2702i cisco autonomous
i have synology and IPTV connected to the ISP router but they didn't get IP, i tried to assign static ip and it worked but if i make the device use the DHCP , it didn't get IP.
i already disabled the ISP DHCP since if i enable it all the wireless client get the ip from the ISP router DHCP. even with IP helper on the interface.
can you please help.
Rasika Nayanajith
Does 2702 got static IP address ?
you can configure it as DHCP server (like any IOS device), however it should be on same network AP is configured with.
what's the issue leaving DHCP on ISP modem/router ?
Rasika
i do prefer to use the Cisco AP as DHCP.
all my wireless devices can get IP but the wired not getting ip.
