Cisco C1111-8PWE Embedd Wireless Controller cannot login
m.yildiz
Level 3
Level 3
Dear Community,
i have an Cisco C1111-8PWE with embedded wireless controller.
From the Router Dashboard i cannot login to the embedded wireless controller.
Always shows wrong credentials.
If i go over the ip of the management from embedded wireless controller i can login, no issues.
Is this a bug or something?
I am using the 17.3.2 firmware, which is the suggested firmware
Any ideas?
Thanks for help
diogobranco
Frequent Visitor
Frequent Visitor
Have you find any solution to the problem reported above?
Regards, Diogo.
i sold it.
annoying stuff, every update something not works
