07-29-2024 09:16 AM
Hi Team,
I am planning to use the Cisco Catalyst 9124E Outdoor Access Point along with the Cisco Aironet Four-Port Dual-Band Polarization-Diverse Antenna (AIR-ANT2513P4M-N) and the Cisco AIR-CAB005LL-R-N Low-Loss Antenna cable. However, I noticed that the CAB005LL-R-N cable has a male and female connector, whereas both the access point and antennas require N-Female bulkhead connectors.
Are there CAB005LL-R-N cables available with male connectors on both ends? If so, what is the part number?
07-29-2024 10:08 AM
- Check if you can find any in : https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2334524.m570.l1313&_nkw=CAB005LL-R-N++two+male+connectors&_sacat=0&_odkw=CAB005LL-R-N+male+connector&_osacat=0
M.
07-29-2024 05:25 PM
Check out
https://www.cisco.com/c/en/us/products/collateral/wireless/aironet-antennas-accessories/product_data_sheet09186a008008883b.html it has all the Cisco Cables, there are N types in there.
Keep in mind the cable extention will add dB loss to the antenna so recommendaiton is to keep as short as possible.
Can you not utilise the cable length that comes with the antenna?
Also I believe you need to order the antenna mounting kit as a seperate line item and potentially one for the AP
