Cisco compatibility with Buffalo AP
dvpro2000
we have built a wifi network using 16 buffalo access points ( as repeaters with WDS links enabled ). We now plan to implement a cisco 1200 as main AP with the 15 buffalo WHR-G54s as repeaters.
We would like to know if this Cisco Unit is compatible with the Buffalo AP.
thank you for your help
john.preves
Level 4
Level 4
Which model AP 1200? Is it a B only radio or something else? What radios are in the Buffalo AP's? You should endeavor to test this out before you plan to implement it.
Are you trying to set up a point to multipoint bridge system or are you doing something else?
Thanks for this answer but we finally tested with a CISCO 1230 and it seems that it will not work. We plan to use a proxim - orinoco between the Cisco unit and the 15 buffalo routers as this orinoco 700 can communicate either with Buffalo AND Cisco
