Cisco controller 5508 with RADIUS authentication
Frederic Husser
Community Member
I'm a trainee in Network and Telecommunication, and I have to do a "model" with a controller, an AP, and a RADIUS server.
Communication and configuration of the lightweight AP has been done.
I use an autonomous access point 1220 as the RADIUS server (no considering it as an AP), and I'm a beginner in RADIUS configuration. I get a "Processing AAA Error 'No Server' (-7) for mobile 00:24:d6:8f:2c:7e" when I launch a debug targetting my PC, connecting to the LAP.
Precursory :
10.137.125.71 is the IP address of the ap1220, working as the RADIUS server
10.137.125.15 is the IP address of the controller.
00:24:d6:8f:2c:7e  is the MAC address of my PC, connecting to the Wi-Fi.
ping works to the RADIUS, to the controller. Each devices are connected by a layer 3 Switch, and ping each others.
The Wi-Fi works when I don't use 802.1X (or when I don't use RADIUS authentication at all)
What I did on the RADIUS server (ap1220 autonomous) :
aaa new-model
radius-server local
nas 10.137.125.15 key password
user test password
user user1 password
AP#show radius local-server statistics
Successes              : 0           Unknown usernames      : 0
Client blocks          : 0           Invalid passwords      : 0
Unknown NAS            : 0           Invalid packet from NAS: 0
NAS : 10.137.125.71 (Pre-configured, it's not used actually)
Corrupted packet       : 0           Unknown RADIUS message : 0
No username attribute  : 0           Missing auth attribute : 0
Shared key mismatch    : 0           Invalid state attribute: 0
Unknown EAP message    : 0           Unknown EAP auth type  : 0
NAS : 10.137.125.15
Username                  Successes  Failures  Blocks
test                              0         0       0
user1                             0         0       0
My WLAN2 configuration, on the controller : (I kept what I thought the more important)
Controller > show wlan 2
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Disabled
      WPA2 (RSN IE).............................. Enabled
         TKIP Cipher............................. Disabled
         AES Cipher.............................. Enabled
                                                               Auth Key Management
         802.1x.................................. Enabled
The debug on the controller : (I kept one more time what I thought the more important)
*May 02 23:02:20.394: 00:24:d6:8f:2c:7e Processing AAA Error 'No Server' (-7) for mobile 00:24:d6:8f:2c:7e
*May 02 23:02:20.395: 00:24:d6:8f:2c:7e Sent Deauthenticate to mobile on BSSID 00:1a:e3:5e:5e:a0 slot 1(caller 1x_auth_pae.c:1276)
I trimmed debug and show wlan, so my post is lighter. I let you the complete version in attached file.
I'm french and my english is not perfect. Thanks to correct me courteously, so I can progress.
Thanks for your support.
Well.... you can't use an autonomous AP as a radius for a WLC.... You would need to use a radius server or use local EAP on the WLC.
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a008093f1b9.shtml
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
5 Replies 5
Scott Fella
What equipment do you have? Here is a doc that shows how to setup a WLC to a Microsoft NPS radius server to authenticate using PEAP.
http://www.room641.com/2012/07/wpa-enterprise-peap-on-cisco-wlc-with-nps/
-Scott
Hi Scott, and thanks for your help.
Actually, I have to set up the local RADIUS server on the autonomous access point 1220. If you have some idea of anything I could have miss or something...
Maybe it would be easier if I use a Microsoft NPS RADIUS server. I will ask my master course.
Scott
-Scott
Oh, I didn't know. So local RADIUS server on an AP is only for other APs ?
I will try with a Microsoft NPS.
Thanks.
Using a true radius server gives you sooooo much more flexability on who can and can't connect and even apply days and time policies.
Scott
-Scott
