CISCO Controller based WLAN
Muhammad Noman
     We have implemented  WLAN using Cisco WLAN controller (5508) and AP (AIR-CAP3502E-E-K9), i  am trying to connec AP (which have gigabit port) with Layer 3 switch  using UTP Cat-6 Cable having 24 AWG Wire Gauge.
What maximun length i can achieve by using above mentioned cable??
Noman
Scott Fella
100 meters if it's cat5, cat5e, cat6 or cat6e
http://en.m.wikipedia.org/wiki/Category_6_cable#section_3
-Scott
Leo Laohoo
Yup.  100 metres and no more.
But in our case we needs the distance of about 180-200 meter, and one more thing we are planning to use POE.
How can we extend the distance??
Noman
Hi Noman,
any cat cable cannot extend more than 100 meters, specally POE , you will need to use a  managed switch with poe to extend cables, you have cut the cable about 100-95 m, then connect the switch then use another cable for remaining length.
i did the same thing for our network
thanks.
Irfan.
