Cisco DPC3925 Bridged Mode dissapear
Marconato92
Hi guys, I'm having a trouble. My internet connection was bad days behind and I reseted my DPC3925 and, SURPRISE, the Working Mode selector dissapear and I can't put it in Bridged Mode to use with my Apple Airport Extreme.
thanks!
12 Replies 12
danmaia
I'm also investigating this problem and can't find any reference to it.
I suspect that it has to do with the current firmware.
It is a life-ended product, and, on the user's guide there's no reference to any bridge option, but we know it was there. Also, there is no documented procedure to update the firmware.
The Open Source Disclaimer points to this e-mail reguarding questions about the software.
Btw, does anyone know what is the lattest firmware?
Maybe after resetting the modem, it refreshed its firmware... I guess.
Same here, the option disappeared and I cannot find any reference to this problem besides here!
Some news, guys? I still waiting :/
Is there solution already on this. Can anyone share please.
Ramon
sobhardw
Please follow the below steps :
Step 0: (Optional) Disable Wireless
Step 1: Have Firefox + Firebug and go to the Maintenance page.
Step 2: Inspect the page with firebug, edit the HTML and find:
<!-- 2 -->
<!-- connection mode -->
(search for — connection mode --)
Now, above <!-- connection mode -->, insert the following code:
<div id="WorkingMode">
<table class="std">
<tr>
<td nowrap width="95">
<script language="javascript" type="text/javascript">
dw(vbcontype2);
</script>Working Mode
</td>
<td>
<select name="working_mode" size="1" id="working_mode" onchange="selectWorkingMode()">
<option name="router" value=0><script language="javascript" type="text/javascript">dw(vbencap4);</script>Router</option>
<option name="bridged" value=1><script language="javascript" type="text/javascript">dw(vbencap5);</script>Bridged</option>
</select>
</td>
</tr>
</table>
</div>
You will now have the option to select bridge mode, if you have not set a password on the device, you must do so now in order to hit submit. You modem will reboot and be in bridge mode. To get back to router mode, hold the reset button for ten seconds.
I tried the method described and had no success.
My results:
- Used firebug as directed;
- Working mode selection appeared, selected Bridged;
- Typed username and password to be set;
- Hit save settings;
- Page refreshed, working mode disappeared (as expected);
- Password was set;
- Modem did not reboot;
- Did a Manual power circle, modem  restarted still in router mode;
What should I do?
Thanks in advance,
Daniel
Guys??? The discussion is not dead!
Doesn't work here too...
The option Router/Bridged appears, but, when you press to Save Settings a black page write 404 FORBIDDEN appears. Look:
I'm same problem.
Hi sobhardw.
Do you found the problem?
Thanks.
This is not working for me either. I get the an 403 FORBIDDEN error.
Same here... help please!
