Cisco Express Mobility Controller (1850)
sejelmohajj
Level 3
Level 3
Team,
We Have Cisco Express Mobility Controller (1850), does it support Integration with Cisco ISE for  Employee (Access to Internal Network) and Guest  (Access to Only Internet) with ISE Portal.
5 Accepted Solutions
 The correct question is 'does it supports external RADIUS?'
YES, it does. I mean, not only ISE but also ISE.
 Take a look on the docs.
-If I helped you somehow, please, rate it as useful.-
Yes It support External Radius, but how about Guest Access with Cisco ISE Portal.
It is the same logic.
See here:
"A number of WLAN Security options are supported on Cisco Mobility Express solution and are outlined below:
OpenP
WPA2ersonalP
WPA2nterprise (External RADIUS, AP)
For Guest WLAN, a number of capabilities are supported:C
CMXGuest Connect
WPA2 Personal
Captive Portal (AP)
 CaptivePortal (External Web Server)
Mobility Express is for quick and simple installs. They have limited features also. Just like with other manufacturers, if your requirements are feature rich, then use a controller.
You can probably get a WLC 2504 or the WLC 3504.
-Scott
6 Replies 6
See here:
OpenP
WPA2ersonalP
CMXGuest Connect
WPA2 Personal
Captive Portal (AP)
How about coa or url redirection ? , I have integrated my other 5520 controller using couple of Access list one for redirection and another one for Internet Only Access.
-Scott
