Cisco Guest Wireless Access Solution - Local Printing
CB90021204
Does Cisco have a solution that provides printing for a guest WLAN. Cisco Guest wireless deployment solutions recommend terminating the guest WLAN on an anchor controller in the DMZ which causes issues when needed to print locally as the print traffic will need to traverse the DMZ anchor controller causing excessive WAN link usage.
Is there a better solution to enable a guest WLAN to print locally?
Rasika Nayanajith
FlexConnect with Split tunneling may work.
Read about this feature & see how that can be used in your branch setup. Here is the Ciscolive presentation slides the above came from.
BRKEWN-2016: Architecting Network for Branch Offices with Cisco Unified Wireless
Rasika
**** Pls rate all useful responses ****
