Cisco ISE 2.1 Time Zone problem
linlinoo
Level 2
Level 2
Now, i am facing some time zone issues with ISE 2.1. When i create Self-Registered Guest Portal, i can add our time Zone (Yangon). Then i change to Sponsored Guest Portal with my authorization profile, this portal is using default time zone (San Jose). How can i change to our time Zone in Sponsored Guest Portal  or delete default time zone (San Jose).
For Self-Registered Guest Portal, i can create account with our time zone
My problem as below because of time zone.
linlinoo
Level 2
Level 2
Finally, i can solve this problem. I have to add time zone into Sponsor Groups settings. To add your time zone,
Work Center->Guest Access->Configure->Sponsor Groups->Create or Edit any account groups->Select the locations that guests will be visiting
Then, you log in with sponsor account and choose your location at the location setting box.
