Cisco ISE - EAP-FAST pac installation / provisioning
sarwarm123
Level 5
Level 5
Hi Guys,
I need to configure EAP-FAST for machine and domain authentication in ISE. In the Cisco documentation they mentioned to use PAC files.
I have managed to generate PAC files through ISE but I don't know how to deploy or install PAC files. My understanding about PAC is only that PAC used for internet proxy. Please correct me if I am wrong.
Please tell me what I need to do with the two PAC files are generated (TunnelPAC, MachinePAC) from the ISE to enable EAP-FAST authentication in ISE. Do I need to install manually PAC files or it can be pushed through GPO? We have Window 7 machines
Thanks in advance
0 Replies 0
