CISCO ISE integration with other vendor wireless lan controller
semakabid1
Hi All !
Currently i am working on one assignment and  willing to integrate the Identity service engine in the  network. the only problem is that wireless network deployed earlier is from other vendor i just need to know that either ISE had the functionality to integrate  with other vendor Wireless controller and can provide the  guest access control . LDAP integration is also required.
Waiting for the help !!!!
abwahid
Level 4
Level 4
As per my knowledge yes, Cisco ISE can integrate with other vendor wireless LAN controller, but with limited one.(Aruba, Rukus) and if you want to add external identity group in your network then LDAP integration is also required.
abwahid
Level 4
Level 4
For the most part ISE is using radius and SNMP to some cases. So yes, but you may lose cisco specific configuration.
Venkatesh Attuluri
https://supportforums.cisco.com/discussion/11435536/wireless-vendor-different-and-cisco-ise-integration
https://supportforums.cisco.com/discussion/11482751/aruba-wireless-controller-and-ise
semakabid1
Thank you so much on your valuable feed and reply,  it help a lot.
