Cisco ISE User Authentication Certificates for Wired and Wirless Users (BYOD)
mishaikh84
Can any one tell me from where we can purchase User Authentication Certificates for Wired and Wireless Users (BYOD) for Cisco ISE. Also Confirm what certificates we required for the purpose.
Please suggest the Website form where we can purchase and ipmort in Cisco ISE certificate Section.
Thanks.
5 Replies 5
mohanak
You can use the self signed certificates, Please verify the link for ISE SCEP support for BYOD:
http://www.cisco.com/c/en/us/support/docs/security/identity-services-engine-software/116068-configure-product-00.html
Dear Mohana,
Thanks for your reply, Can you please confirm me in regards EAP-TLS certificate, which authorities you recomend if i go to Go dadday or very Sign to buy it and then import in ISE.
Looking forward for your reply.
Muhammad Imran Shaikh
Resident Engineer, IT Network Section - PPL
Mobile : 0092-312-288-1010
LinkedIn : pk.linkedin.com/pub/muhammad-imran-shaikh/10/471/b47/
you can use verisign
Dear Mohana,
Can you please provide me the weblink of certificate from verisign website, because i can't locate exact certificate. All i can see on website are SSL based certificates can not see TLS based certificate.
Moin Ilyas
Level 4
Level 4
Adding to Mohanak, please refer: http://www.cisco.com/c/dam/en/us/td/docs/security/ise/how_to/HowTo-60-BYOD-Using_Certificates_For_Differentiated_Access.pdf
