Cisco Lightweight AP - Belkim WeMo Connectivity
paul.jardencs
Hello ... has anyone had any success Connecting Belkin WeMo Devices (Light Switch) to a Cisco Lightweight Access Point Infrastructure?
I have a Cisco WLC 5508 w/ Software v7.4.121 and Cisco 1262's AP's. I am using WPA2 Personal on the WLAN I am trying to get my Belkin WeMo Light Switch be able to associate to the WLAN and communicate to Tablets/Smartphones (iOS and Android) that support the Belkin Wemo App.
I get to the point of setup that the Belkin Wemo Device associates to the WLAN however I cannot communicate to it via my Smartphone and/or Tablet via the APP. I can however ping the WeMo Device on the network.
P2P Blocking Action is disabled on the WLAN.
8 Replies 8
Rasika Nayanajith
Pls attach "show wlan <wlan_ID>" output where for the WLAN you created to associate these devices.
Rasika
*** Pls rate all useful responses ****
hi Rasika,
I have tried to disable TKIP however same results.
I have even tried to connect the WeMo Device via "NoSecurity" and still receive the same results.
Hi Paul,
Did you test this setup in any other environment, like home WiFi setup just to make sure WeMo is working.
Rasika
paul.jardencs
Hello Rasika,
As requested listed below is the show wlan information.
(Cisco Controller) show>wlan 5
WLAN Identifier.................................. 5
Profile Name..................................... Guest
Network Name (SSID).............................. Guest
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
  Client Profiling Status ....................... Disabled
   DHCP ......................................... Disabled
   HTTP ......................................... Disabled
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
Number of Active Clients......................... 23
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 1800 seconds
User Idle Timeout................................ 300 seconds
--More-- or (q)uit
User Idle Threshold.............................. 0 Bytes
NAS-identifier................................... WLC5508-U1
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ guest
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
mDNS Status...................................... Enabled
mDNS Profile Name................................ default-mdns-profile
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
PMIPv6 Mobility Type............................. none
Quality of Service............................... Silver
Per-SSID Rate Limits............................. Upstream      Downstream
Average Data Rate................................   0             0
Average Realtime Data Rate.......................   0             0
Burst Data Rate..................................   0             0
Burst Realtime Data Rate.........................   0             0
Per-Client Rate Limits........................... Upstream      Downstream
--More-- or (q)uit
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ Global Servers
   Accounting.................................... Global Servers
      Interim Update............................. Disabled
   Dynamic Interface............................. Disabled
   Dynamic Interface Priority.................... wlan
--More-- or (q)uit
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
   FT Support.................................... Disabled
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Disabled
      WPA2 (RSN IE).............................. Enabled
         TKIP Cipher............................. Enabled
         AES Cipher.............................. Enabled
                                                               Auth Key Management
         802.1x.................................. Disabled
         PSK..................................... Enabled
         CCKM.................................... Disabled
         FT-1X(802.11r).......................... Disabled
         FT-PSK(802.11r)......................... Disabled
         PMF-1X(802.11w)......................... Disabled
         PMF-PSK(802.11w)........................ Disabled
      FT Reassociation Timeout................... 20
      FT Over-The-DS mode........................ Enabled
      GTK Randomization.......................... Disabled
--More-- or (q)uit
      SKC Cache Support.......................... Disabled
      CCKM TSF Tolerance......................... 1000
   WAPI.......................................... Disabled
   Wi-Fi Direct policy configured................ Disabled
   EAP-Passthrough............................... Disabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   FlexConnect Local Switching................... Disabled
   flexconnect Central Dhcp Flag................. Disabled
   flexconnect nat-pat Flag...................... Disabled
   flexconnect Dns Override Flag................. Disabled
   FlexConnect Vlan based Central Switching ..... Disabled
   FlexConnect Local Authentication.............. Disabled
   FlexConnect Learn IP Address.................. Enabled
   Client MFP.................................... Optional
   PMF........................................... Disabled
   PMF Association Comeback Time................. 1
   PMF SA Query RetryTimeout..................... 200
   Tkip MIC Countermeasure Hold-down Timer....... 60
--More-- or (q)uit
AVC Visibilty.................................... Disabled
AVC Profile Name................................. None
Flow Monitor Name................................ None
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Assisted Roaming Prediction Optimization......... Disabled
802.11k Neighbor List............................ Disabled
802.11k Neighbor List Dual Band.................. Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
 Mobility Anchor List
 WLAN ID     IP Address            Status
802.11u........................................ Disabled
MSAP Services.................................. Disabled
Please "untick TKIP" option under SSID WPA2 security & see if that makes any difference.
Rasika
Reuben Farrelly
Level 3
Level 3
I've seen similar things happen when these devices rely on multicast for discovery and connectivity.  In my case I've got a LIFX device which doesn't seem to work when I centrally switch the WLAN.
Are you able to test this out by running your WLAN in FlexConnect mode and switching the data locally rather than centrally and see if that helps?
Hi Reuben,
I had a suspicion that Multicast may be causing the issue, however I could not perform a packet capture at the time of my troubleshooting.
Unfortunately all of my AP's are "Local" Connected in a Production Environment. However sometime this weekend, I am going to change one of the AP's to FlexConnect with Local Switching and see if this corrects the issue.
I will let you know the results .. thanks for the advise.
I was wondering if anyone has figured this issue out? I have 10 WEMO devices and only my Android phones will see it. None of our Apple devices will see ANY of the WEMO deivices. Not to mention that It took days for me to upgrade all firmware but one. Still have one left that will not update even though the update is available.
