Cisco ME 1852i slow in internet speed
caicai1986
Hi All,
Recently i have a problem with the deployment. I have just get a Mobility Express version AIR-AP1852i-K-K9C. And i have 1 internet speed with 800Mbps. but when after change to 1852i, i just able to get 200 - 400Mbps (Rarely to get 500Mbps above). The environment is only 1 device connected, that is Apple MACBook Pro with 1300Mbps connection. The internet conenction is work perfectly with my local LAN. (i can get 700+Mbps all the time).
What i had done:
1. Optimize with the RF optimizer.
2. Set it to 80Mhz bandwidth.
3. Set different type of QoS. (It is nor working)
4. Turn on/ Off for the ME Firewall or any advance features.
5. Upgrade to latest version 8.8.
May i know is that the ME got any features or setting that slow down the connection?
BR,
Chong
I have simulare problem, try turning of application visability , it slows down the throughput. My problem is with older aps 1700 and 3700
CCIE-Collaboration #24527
