Cisco Meraki MR32/MR72 AP BLE Question
kridwinkler
I have read that the access points mentioned in the title are able to scan for iBeacon devices. So, I need to know if these information can also be transmitted via http in the way WiFi information get send? Would I then be able to use the CMX API to receive these information (UUID, rssi, etc.) from a windows PC?
Krid
Saurav Lodh
Level 7
Level 7
Not sure it the info can be transmitted over http, http is just an application however, BLE ( bluetooth low energy) is the transmission technology used in this.
Hi Saurav,
thanks for your reply. That's true, but I would be interested to know if the Meraki is able to transmit the received BLE (iBeacon) data to another application via WiFi(or http or whatever). Is there a way to find out?
