Cisco Mini-PCI Wireless Adapter on IBM T30 laptop
BitsnyBytes
Has anyone out there had any luck with getting the Cisco Aironet 350 Mini-PCI working on an IBM laptop with Linux? I have it working fine with Windows XP Pro but would like to get it working with Linux. Currently have RedHat 9 ( 2.4.x kernel ) installed but am willing to move to any popular Linux distro that may work? Each time I run the install shell script, even with the compile option, I do get a successful install message ... but attempts to run the ACU utility result in a "Radio not found" message.
Not applicable
If you have access to Cisco BugToolKit , you can check there to find if there are any known issues in this .
