bridging and point to multipoint
garybr
I have 900 yards to bridge two bulidings can I set up two Cisco 1200 AP'for that bridge?
2. Point to multipoint
I am bringing up a point to multipoint network, besides setting; data rates @11mbps, turn off broadcast SIDD, set point as ROOT and multipoint as Repeaters is there anything else I should be aware of?
thanks
gary
gamccall
Level 4
Level 4
APs are not bridges. You need to look at the 1300s instead of the 1200's, or try to pick up some BR350s (not AP350s!).
You'll set your non-root bridges to "non-root", not "repeater". Repeater is an access point mode, not a bridging mode.
thanks for the reply
I am using Cisco 1200 APs in the point to multipoint design. The Root 1200 and the Multipoint 1200s are set to non root?
If you want this scenario:
wired lan - wireless device 1 ... wireless device 2 - wired lan
... wireless device 3 - wired lan
...then you can not accomplish this with AP1200's. You need bridges, presumably 1300's. WD1 will be set as root bridge; WD2 and WD3 will be set as non-root bridge.
If instead, you want this scenario:
wired lan - wireless device 1 ... wireless device 2 ... wireless clients
... wireless device 3 ... wireless clients
...then you can do that with AP1200's. WD1 will be a root access point; WD2 and WD3 will be repeater access points.
