Cisco Mobility Express- Unable to See AP after Setting up Air Provision
Sudhir Gupta
Hi ,
we are facing below issue after setting up initial Config (After Air Provision Setup)
we have don the Basic Config all Ip address, SSID etc.
We are unable see AP and also not Broadcasting.
after troubleshooting i found the below error
Radio Mode is changed from FlexConnect to FlexConnect
DOT11_CFG[1] Radio Mode is changed from FlexConnect to FlexConnect
21 Replies 21
 Flexconnect is not an option for Mobility Express. You must be not using Mobility Express on the AP side.
 If you have capwap APs you may have to converte them to mobility express.
 With show version command you can make sure you are handling mobility express AP. Look for Mobility Express somewhere on the output.
 Check this out and make the conversion if necessary then try to join again.
 Mobility Express is meant to be easy.
-If I helped you somehow, please, rate it as useful.-
Hi Flavio,
I have Converted the AP in to ME.
after that i can see the Cisco Air Provision ssid broadcasting.
then i have configured the ME clicking on Cisco Air Provision.
as my setup is complete then AP reboots for new configuration.and when AP comes up, i can login with the new credentials and after that i cant see Any Access Point on the TAB of Access point.
and also it doesn't Broadcast.
what i feel that if can see the AP in the Access point TAB then it will broadcast..
pls revert asap if required any output just let me know.
@Sudhir Gupta  can you tell me which APs model do you have?
Also, after the WLC is configured, did you create any new SSID ? If does, did you change the status to enable?
Let me know and let´s see what else we can help you.
Hi Flavio,
i have 1815i Model.
Yes i have created a SSID name ABC Network and also i have enabled the ssid.
Rgds/Sudhir
Hi Flavio,
i am online..if possible can you pls revert asap...
Adding Few Points
on wireless setting it should show AP
Wireless Settings > Access Points.
Access Point with the P
this i unable to see..
Rgds/Sudhir
Well, this solution is meant to be simple. As far as I know there´s not much you can do.
Feel things you can check is network connectivity, maybe try to boot everything and start over again, try to log on the Access Point subordinate and take via CLI and take a look on logs. There are also some debug commands you can run on the Controller like:
debug capwap detail enable
debug capwap events enable
debug capwap errors enable
 Try to share logs here.
Hi Falvio,
let me check this debug, will update you on this..
also what i have notice that error "switching Flexconnect to Flextconnect mode".as i mentioned in my 1st post.
does this mean that AP is going to flexconnect mode, and may  this will be the reason that ap is not showing in the  GUI in wireless setting.
Also Thanks for the Quick Reply.
Rgds/Sudhir
According to cisco:
"Cisco Mobility Express has been built on the FlexConnect architecture and supports central authentication of clients and local switching of data traffic. Similar to how it is in FlexConnect, APs running Cisco Mobility Express support both the Connected and Standalone Mode."
Try to get those logs and let´s see if they tell us something.
Hi Flavio,
attaching some snapshots for your reference.
one thing i notice that there is no WLAN ID, even i am add wlan is example 1,2,3 etc,
Hi Flavio.
pls find below logss from apshell mode
[*10/28/2017 20:00:15.1003] CAPWAP State: DTLS Setup
[*10/28/2017 20:00:15.2603]
[*10/28/2017 20:00:15.2603] CAPWAP State: Join
[*10/28/2017 20:00:15.2703] Sending Join request to 192.168.0.164 through port 5272
[*10/28/2017 20:00:15.2703] Join Response from 192.168.0.164
[*10/28/2017 20:00:15.3803]
[*10/28/2017 20:00:15.3803] CAPWAP State: Image Data
[*10/28/2017 20:00:15.4603] do NO_UPGRADE, part1 is active part
[*10/28/2017 20:00:15.4603] CAPWAP State: Configure
[*10/28/2017 20:00:15.4703] DOT11_CFG[0] Radio Mode is changed from FlexConnect to FlexConnect
[*10/28/2017 20:00:15.4703] DOT11_CFG[1] Radio Mode is changed from FlexConnect to FlexConnect
[*10/28/2017 20:00:18.3303] Re-Tx Count=1, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*10/28/2017 20:00:21.1803] Re-Tx Count=2, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*10/28/2017 20:00:24.0303] Re-Tx Count=3, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*10/28/2017 20:00:26.8803] Re-Tx Count=4, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*10/28/2017 20:00:29.7303] Re-Tx Count=5, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*10/28/2017 20:00:29.7403]
[*10/28/2017 20:00:32.5903] Re-Tx Count=6, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*10/28/2017 20:00:32.5903] Max retransmission count exceeded, going back to DISCOVER mode.
[*10/28/2017 20:00:32.5903] CAPWAP State: DTLS Teardown
[*10/28/2017 20:00:37.3403] In Flexconnect standalone, skip radio reset
[*10/28/2017 20:00:37.3803] Discovery Response from 192.168.0.164
[*10/28/2017 20:00:46.8403]
[*10/28/2017 20:00:46.8403] CAPWAP State: DTLS Setup
[*10/28/2017 20:00:47.0103]
[*10/28/2017 20:00:47.0103] CAPWAP State: Join
[*10/28/2017 20:00:47.0103] Sending Join request to 192.168.0.164 through port 5272
[*10/28/2017 20:00:47.0203] Join Response from 192.168.0.164
[*10/28/2017 20:00:47.1303]
[*10/28/2017 20:00:47.1303] CAPWAP State: Image Data
[*10/28/2017 20:00:47.2103] do NO_UPGRADE, part1 is active part
[*10/28/2017 20:00:47.2103] CAPWAP State: Configure
[*10/28/2017 20:00:47.2203] DOT11_CFG[0] Radio Mode is changed from FlexConnect to FlexConnect
[*10/28/2017 20:00:47.2203] DOT11_CFG[1] Radio Mode is changed from FlexConnect to FlexConnect
[*10/28/2017 20:00:50.0703] Re-Tx Count=1, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*10/28/2017 20:00:52.9203] Re-Tx Count=2, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*10/28/2017 20:00:55.7803] Re-Tx Count=3, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*10/28/2017 20:00:58.6303] Re-Tx Count=4, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*10/28/2017 20:01:01.4803] Re-Tx Count=5, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*10/28/2017 20:01:04.3303] Re-Tx Count=6, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*10/28/2017 20:01:04.3303] Max retransmission count exceeded, going back to DISCOVER mode.
[*10/28/2017 20:01:04.3303] CAPWAP State: DTLS Teardown
[*10/28/2017 20:01:09.0803] In Flexconnect standalone, skip radio reset
[*10/28/2017 20:01:09.1203] Discovery Response from 192.168.0.164
[*10/28/2017 20:01:18.5903]
[*10/28/2017 20:01:18.5903] CAPWAP State: DTLS Setup
[*10/28/2017 20:01:18.7503]
[*10/28/2017 20:01:18.7503] CAPWAP State: Join
[*10/28/2017 2
Sudhir Gupta
is there any update for this...
Hi @Sudhir Gupta
Sorry for take so long.
 We can see that AP sent join request and WLC respond with join response.
 But the process stops here.
Make sure time and date is correct on the WLC. Of course both need to be mobility express but you already fixed that right.
You can try to collect some logs from the WLC side as well.
