Cisco Mobility Express- Unable to See AP after Setting up Air Provision
Sudhir Gupta
Hi ,
we are facing below issue after setting up initial Config (After Air Provision Setup)
we have don the Basic Config all Ip address, SSID etc.
We are unable see AP and also not Broadcasting.
after troubleshooting i found the below error
Radio Mode is changed from FlexConnect to FlexConnect
DOT11_CFG[1] Radio Mode is changed from FlexConnect to FlexConnect
21 Replies 21
Hi Flavio,
thanks for the reply.,
my ap model is ai-ap1815i-i-k9
and i am in india , is there will domain regulatory issue, for this cause
Hi Flavio,
if you are online, then you pls revert , need your suggestion
thanks in advance
Hi Flavio,
just came to conclusion that its a regulatory domain issue.
just want to ask can we change/add different country domain to Mobility express, like we do in Plain WLC like 2504.
Rgds/SK
Yes you can.
-If I helped you somehow, please, rate it as useful.-
Hi Flavio,
its Done after adding.
may i know how to solve this issue ? i have same issue yesterday .
@Flavio Miranda Sorry to rehash an old topic, but I seem to be running into precisely this problem and didn't see a real solution on this thread. Do you know what could cause me to not see my AP (1562e) in the Mobility Express window?
