12-17-2015 11:21 AM - edited 07-05-2021 04:24 AM
Hello!
In Russian Main Cancer Research Center we have 6 Cisco 4400 wireless controllers and more then half accespoints - 1000 series (1020). Now we plan to use Cisco Prime 3.0 to manage wired and wireless networks. The problem is - last software that support 1000 series AP is 4.207 but this release is not working with Cisco Prime 3.0. I upgrade spare controller to 7.x version and controller can register to Prime with no problem. Is it possible to use WLC 4400 with 4.x software version in Cisco Prime 3.0 ?
Solved! Go to Solution.
12-21-2015 02:59 AM
Thanks! And what about 2.2?
PI do not support WLC running anything lower than 7.0.98.X. Read THIS.
If you need something to support AP1000 model then you may need to look into WCS.
12-17-2015 12:01 PM
Additional info
Same situation on WISM1
Wism with 7.х software works good
Wism with 4.2 - not work
12-17-2015 04:38 PM
I do not think so.
It is good if you could have a plan to migrate these 1000 series AP to somewhat supported by Cisco.
Rasika
12-17-2015 10:00 PM
We have a plan to change 1000 series AP, but I talking about support WLC 4400 and WISM1 with 4.x software by Cisco prime 3.0.
12-20-2015 12:22 AM
PI 3.0 cannot support 4.X firmware.
12-21-2015 02:49 AM
12-21-2015 02:59 AM
