Cisco Prime Infrastructure 2.0 Problems
denos8346
Visitor
                   I have recently upgraded to version 2.0 with the latest software patch and most things seem to be ok. A few things I've noticed was that my maps do not zoom in like they did in version 1.2 which really sucks. I also recently created a template to move my lightweight AP's to another controller and it shows success but no AP takes the change. Has anyone else had these issues and if so has anyone had them resolved?
kdavison007
Level 3
Level 3
I had the same mapping issues you're talking about.  I fixed it by going into the main maps summary screen and choosing export from the drop down in the top right.  If you export the maps and then reimport them the zoom level is fixed.  I'd try this on one map first to make sure everything looks okay and then you can do multiple maps and or buildings at a time.  I had all 100+ maps of ours updated in an hour or so doing this and all the AP locations were still fine.  Make sure you log in to Prime using root so you can export/import using the XML option.
