Cisco Prime infrastructure for wireless
refaatcisco1234
Greetings,
I would like to verify :
1- The Cisco prime  server requirement as a  VM  . Trying to host it on a VM
2- what is the latest Cisco prime IOS version on a VM ?
3- how to identify the license required to support 1000 AP and 4 WLC
Sandeep Choudhary
Go with cisco Prime 3.4
If you have 4 AP and 1000 AP then you should go with Express Setup:
Check the Table 1 &Table 2, You will get all your answer.
https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-4/quickstart/guide/bk_Cisco_Prime_Infrastructure_3_4_0_Quick_Start_Guide.html#con_1070036
Dont forget to rate helpful posts
