Cisco RM-1252G-A-K9 can't access web interface
mistertokr
I hope I am in the correct forum for this topic?
For some reason I cannot access the web interface in order to configure this device. I have it connected to a router (DHCP). The router assigns an IP Address and I can ping it. If I attempt to go to that IP Address in any web browser. the page cannot be displayed. I've reset it several times. I have 2 of these and same problem. Am I missing something obvious? I sure hope so...
Moin Ilyas
Level 4
Level 4
To re-enable the web-browser interface, enter this global configuration command on the CLI:
ap(config)# ip http server
Hope that helps.
I have no idea how the CLI works or how to connect and/or access it
Connecting to the Access Point Locally
If you need to configure the access point locally (without connecting it to a wired LAN), you can connect a PC to its console port by using a DB-9 to RJ-45 serial cable.
Follow these steps to open the CLI by connecting to the access point console port.
Step 1 Connect a nine-pin, female DB-9 to RJ-45 serial cable to the RJ-45 console port on the access point and to the COM port on the PC.
Step 2 Set up a terminal emulator on your PC to communicate with the access point. Use the following settings for the terminal emulator connection: 9600 baud, 8 data bits, no parity, 1 stop bit, and no flow control.
Assigning an IP Address Using the CLI
When you assign an IP address to the access point using the CLI, you must assign the address to the BVI. Beginning in a privileged EXEC mode, follow these steps to assign an IP address to the access point BVI using the console port:
Command
Purpose
Step 1
enable
Enter privileged EXEC mode.
Step 2
configure terminal
Enter global configuration mode.
Step 3
Interface bvi1
Enters interface configuration mode for the BVI.
Step 4
ip address address mask
Assigns an IP address and subnet mask address to the BVI.
Step 5
end
Return to privileged EXEC mode.
Saurav Lodh
Level 7
Level 7
Reload the image using MODE button
refer
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/1250/installation/guide/1250HIG_TD-Book-Wrapper.pdf
