Cisco's antenna patterns files for Radio Mobile
vagnervale
hi guys,
Anyone has the Cisco's antenna patterns files to plot on Radio Mobile. Indeed, I would like the file ".ant" for the 5,8GHz-17 dBi sector antenna (AIR-ANT5117S-N).
Vagner Vale
carenas123
Level 5
Level 5
Here is the URL for the Cisco Aironet 17-dBi Sector Antenna (AIR-ANT5117S-N). http://www.cisco.com/en/US/docs/wireless/antenna/installation/guide/ant5117S.html
Do you have a link for the .ant file though?
Biker Frog
I need something similar. I need MSI PLN or ADF for AIR-ANT2547V antenna. Anyone have anything they can send link to this file?
I ended up using a program to draw the pattern in from the spec sheet.
https://www.wireless-planning.com/antenna-pattern-editor
