Cisco Secure ACS validation problem
s.maranan1
Community Member
Hi!
We are currently experiencing error with our Cisco ACS ver 5.4.
It has 3 SSID: SEPHIL, SUPPORT, GUEST
SUPPORT and GUEST has DHCP enabled
SEPHIL is static.
Before clients under SEPHIL SSID will not be able to connect if we did not configure the MAC addr and static IP on End Statipn Filter.
but now the problem is once i create the user on Identity stores it can connect to SEPHIL SSID even MAC Addr and IP are not yet configure on the system. Please advice us on the how to solve.
Thank you in advance
0 Replies 0
