Cisco Tacacs(ACS) help
kannan.kannan
Hi Team,
We are running virtual TACACS( Cisco ACS), need to check if Centrify is supported on these appliances?
We want to install monitoring tool agent on this devices? I meane centtify agent on this device?
Please advice is it possible.
Kannan
Amjad Abdullah
You can not run agents on the ACS. You can only use SNMP with the ACS for monitoring.
Hope this helps.
Amjad
Rating useful replies is more useful than saying "Thank you"
Hi Amjad,
Can you please send me URL document link for this issue.
we need do know from cisco document
You might be better off asking your local SE if they can get you one or else maybe a TAC case and an email from them stating that it is not supported will work.
-Scott
Shaoqin Li
Level 3
Level 3
do you mean the centrify which integrate microsoft AD?
