Cisco Virtual Wireless Controller
garry cordess
Level 3
Level 3
Does the Cisco Virtual WLC support the 1230AP?
There is a list of supported AP's from the data sheet the1230 isnt listed, maybe shoould assume no support?!
http://http://www.cisco.com/en/US/partner/prod/collateral/wireless/ps6302/ps8322/ps12723/data_sheet_c78-714543.html
Garry.
Stephen Rodriguez
no, it doesn't.  But it has to do with the 7.3 code, as that is the lowest code the vWLC can run.
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn73.html
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Stephen Rodriguez
HTH,
Steve
HTH,
Steve
Hi steve,
Ok thanks for that.
cheers,
Garry.
manjeets
Level 5
Level 5
it will be do with the 7.3 code,
