Cisco Virtual Wireless Controller
Murad*
Level 5
Level 5
hi
i have Cisco Virtual Wireless Controller that are supported 3000 Access Points , and because this is my first try to work wit ( virtual ) device my query here , is this VM worked normally with AP1142n or not ?
and if there any tips can help me to dialing with this machine please guide me to it .
this logg from AP
*Oct 24 11:49:25.000: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.33.33:5246
*Oct 24 11:49:25.087: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Oct 24 11:49:25.087: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Oct 24 11:49:25.089: %LWAPP-4-CLIENTEVENTLOG: Not sending change state post as the radio admin is down, lrad state = 5
*Oct 24 11:49:25.090: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Oct 24 11:49:25.145: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Oct 24 11:49:26.086: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Oct 24 11:49:26.115: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Oct 24 11:49:26.119: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Oct 24 11:49:27.109: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Oct 24 11:49:27.114: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Oct 24 11:49:27.141: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Oct 24 11:49:27.145: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Oct 24 11:49:27.150: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Oct 24 11:49:28.140: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Oct 24 11:49:28.146: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Oct 24 11:49:28.171: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Oct 24 11:49:29.172: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Oct 24 11:49:35.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.33.33 peer_port: 5246
*Oct 24 11:49:35.483: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 192.168.33.33 peer_port: 5246
*Oct 24 11:49:35.484: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.1.3
17 Replies 17
As mentioned by Leo, your WLC is configured for the US regulatory domain, where your AP is for Europe. Under AP details, check under advanced and ensure the correct country code is selected.
i think this is the problem : WLC MIC Certificate Types........................ SHA1
where from i can change it to SH1/SH2 ?
Jurgens L
Level 8
Level 8
Check your time and date settings on the vWLC, the AP won't join if the vWLC is set to default (the year 2000).
