cisco vwlc ap join problem
FARO15ful
Frequent Visitor
Frequent Visitor
created new virtual machine with 8.10.196.0 version. but when ap try join wlc can download image from wlc.
*Mar 3 09:32:25.255: %CAPWAP-6-AP_IMG_DWNLD: Required image not found on AP. Downloading image from Controller.
*Mar 3 09:32:25.259: Loading file /ap3g2...
ERROR: Image is not a valid IOS image archive.
Download image failed, notify controller!!! From:8.2.170.0 to 0.0.0.0, FailureCode:3
*Mar 3 09:35:10.347: capwap_image_proc: problem extracting tar file
ap ios image is ap3g2-k9w8-mx.153-3.JC15 witch connected before to 8.2.170.0
what is the problem?
Mark Elsen
 - It's possible that the current image on the AP is too old for an automatic upgrade by the controller; try
    to install the needed image manually on the AP according to the AP model :
    an example can be seen in https://blog.it-playground.eu/lightweight-ap-manual-firmware-upgrade/
    Of course you will need to change the image name according to the AP name and capwap image for 8.10.196.0
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Mark Elsen
 M.
I just tftp upload Recover image (ap3g2-rcvk9w8-tar.153-3.JPQ3.tar) to ap ant it's worked. https://software.cisco.com/download/home/285029865/type/280775090/release/15.3.3-JPQ3
Thank you for your advise
