Cisco wall-plate
Is there a Cisco wall-plate model? Something similar to HP E-MSM317 and Ruckus 7025?
I had look on the web but couldn't find anything.
Thanks and regards,
Vin
Scott Fella
No... Cisco just has the typical various mounting brackets for the access points.  You can always run cable to a single/double gain box and use the universal mounting bracket.
Cisco AIR-AP-BRACKET-2= AP Universal Mounting Bracket
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Thanks Scott but this is not what I'm looking for.
Having a wall-plate like the ZF7025 within a room, besides the small form factor and a good wireless coverage, you can take advantage of 4 LAN ports among which 1 PoE output port that you can use to connect a VoIP phone for example.
I'm quite surprised that Cisco doesn't have this type of model.
Vin
Scott Fella
No Cisco doesn't have anything like that. You would have to use what you have posted.
-Scott
