Cisco WAP321 Wireless Access Point issue
aldobarani
Having troubles loading a certificate in System security/802.1X Supplicant
I tried to upload *.car and *.msc certificates, but the device aborted the upload at each attempt.
Please let me know what format would work.
Thank you.
aldobarani
bump
Naveen Kumar
Level 4
Level 4
Configuration of 802.1X Authentication on  the Cisco WAP121 and WAP321 Access Points
Objective
In 802.1x authentication, when a host (also known  as the supplicant) tries to connect to a secured network, a network device  called the authenticator checks with an authentication server that supports  RADIUS and EAP to verify the identity of the supplicant. In this way, the  network device provides an additional layer of security to the network. This  document explains how to configure the WAP121 and WAP321 access points as a  supplicant for 802.1x authentication.
Applicable Devices
• WAP121
• WAP321
Software Version
• v1.0.2.3  (WAP121 and WAP321)
802.1X Supplicant Configuration
Step 1. Log in to the Access Point Configuration  Utility and choose System Security > 802.1X Supplicant. The  Supplicant Configuration page opens:
Step 2. Check Enable in the Administrative  Mode field to enable the device to act as a supplicant in 802.1X  authentication.
Step 3. Choose the appropriate type of Extensible  Authentication Protocol (EAP) method from the drop-down list in the EAP Method  field.
• MD5 — MD5 is an algorithm which is used to  encrypt data of any size in to 128 bit, the MD5 algorithm uses public key  cryptosystem to encrypt the data.
• PEAP — Protected EAP is an authentication method  that provides enhanced security, PEAP authenticates wireless LAN clients through  digital certificates issued by the server by creating an encrypted SSL/TLS  tunnel between the client and the authentication server.
• TLS — Transport Layer Security (TLS) is a  cryptographic protocol that provides security and data integrity for  communication over the Internet. When a server and client communicate, TLS  ensures that no third party tampers the original message. Most of the functions  of MD5 are used in TLS.
Step 4. Enter the username and password that the  access point uses to get authenticated from the 802.1X authenticator in the  Username and Password fields. The length of the username and password must be  from 1 to 64 alphanumeric and symbol characters.
Step 5. Click Save to save the settings.
Note: The Certificate File Status area shows  whether the certificate file is present or not. The SSL certificate is a  digitally signed certificate by a certificate authority that allows the web  browser to have a secure communication with the web server. To manage and  configure the SSL certificate refer to the article Secure Socket Layer (SSL)  Certificate Management on the Cisco WAP121 and WAP321 Access  Points.
Ref Link:
http://sbkb.cisco.com/CiscoSB/GetArticle.aspx?docid=6e0ac5f97c0042838381daacfbe087a6_Configuration_of_802_1X_authentication_on_the_Cisco_WAP121_a.xml&pid=2&converted=0
