10-30-2012 01:17 AM - edited 07-03-2021 10:56 PM
Hi, I'm currently running WCS 7.0.220.0 and WLC firmware 7.0.220.0. I need to support 3600 WAPs, does anyone know what controller firmware I can go up to that is still supported by WCS? I have read that 7.1.91.0 controller firmware is still compatible with WCS 7.0.220.0 but keen to know if I can go to a newer controller firmware?
Solved! Go to Solution.
10-30-2012 03:24 AM
The 3600 is supported from code 7.2 but the WCS does not support code 7.2 so you should look at upgrading to Cisco NCS or Cisco Prime Infrastructure.
Additionally 4400 and 2100 series controllers do not support code 7.2.
10-30-2012 04:57 AM
Here is a link to the compatibility matrix
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html
10-30-2012 03:24 AM
10-30-2012 04:57 AM
