Cisco Wireless AP
umiedotre9
Community Member
Good day,
I’ve been using an old Ruckus wireless AP. It’s served me well however the device is no longer supported i.e no further firmware updates.
The AP is for a small office with few users. Any recommendations on a Cisco AP? Something simple will do. Reliability and stability are the requirements here.
Thanks.
Mark Elsen
  https://www.cisco.com/c/dam/assets/prod/wireless/cisco-wireless-selector-tool/index.html
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Scott Fella
Just to add, if you are looking for new equipment, look at the EWC access points, specifically the 9100’s. They can run a controller feature that doesn’t requires a separate hardware.
https://www.cisco.com/c/en/us/products/collateral/wireless/embedded-wireless-controller-catalyst-access-points/white-paper-c11-743398.html
-Scott
finleyjamessz
Community Member
You can upgrade to the another router like Cisco dpc3825. It might work for you. I am using it for the last 2 years and have not faced any major issues.
