cisco wireless client issue
Thushara
Level 3
Level 3
hello Team,
here the issue is the client is facing the wifi slowness.
 wlc model: 5508
WLC IOS version:8.2.166.0
Ap-model:AIR-CAP2602I-E-K9
Client machine:mac book
Here the issue is  when the mac book clients trying to connect to wifi(corporate-ssid), the client is getting connected to 802.11bn protocol and simultaneously the client is facing slowness.
Tried disabling the radio 2.4 radio in the access points , even after the client is connecting to same radio in a different AP.
WLAN-Configuration
(Cisco Controller) >show wlan 1
WLAN Identifier.................................. 1
Profile Name..................................... xyz
Network Name (SSID).............................. xyz
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
Client Profiling Status
    Radius Profiling ............................ Disabled
     DHCP ....................................... Disabled
     HTTP ....................................... Disabled
    Local Profiling ............................. Disabled
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
ATF Policy....................................... 0
Number of Active Clients......................... 86
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 43200 seconds
User Idle Timeout................................ Disabled
Sleep Client..................................... disable
Sleep Client Timeout............................. 720 minutes
User Idle Threshold.............................. 0 Bytes
NAS-identifier................................... none
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ management
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
WLAN Layer2 ACL.................................. unconfigured
mDNS Status...................................... Disabled
mDNS Profile Name................................ unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
Tunnel Profile................................... Unconfigured
PMIPv6 Mobility Type............................. none
    PMIPv6 MAG Profile........................... Unconfigured
    PMIPv6 Default Realm......................... Unconfigured
    PMIPv6 NAI Type.............................. Hexadecimal
    PMIPv6 MAG location.......................... AP
Quality of Service............................... Silver
Per-SSID Rate Limits............................. Upstream      Downstream
Average Data Rate................................   0             0
Average Realtime Data Rate.......................   0             0
Burst Data Rate..................................   0             0
Burst Realtime Data Rate.........................   0             0
Per-Client Rate Limits........................... Upstream      Downstream
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... 802.1P (Tag=0)
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ 10.1.1.1 1812 *
   Accounting.................................... Global Servers
      Interim Update............................. Enabled
      Interim Update Interval.................... 0
      Framed IPv6 Acct AVP ...................... Prefix
   Dynamic Interface............................. Disabled
   Dynamic Interface Priority.................... wlan
Local EAP Authentication......................... Disabled
Radius NAI-Realm................................. Disabled
Mu-Mimo.......................................... Enabled
Security
   802.11 Authentication:........................ Open System
   FT Support.................................... Disabled
--More-- or (q)uit
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Disabled
      WPA2 (RSN IE).............................. Enabled
         TKIP Cipher............................. Disabled
         AES Cipher.............................. Enabled
      OSEN IE.................................... Disabled
      Auth Key Management
         802.1x.................................. Enabled
         PSK..................................... Disabled
         CCKM.................................... Disabled
         FT-1X(802.11r).......................... Disabled
         FT-PSK(802.11r)......................... Disabled
         PMF-1X(802.11w)......................... Disabled
         PMF-PSK(802.11w)........................ Disabled
         OSEN-1X................................. Disabled
      FT Reassociation Timeout................... 20
      FT Over-The-DS mode........................ Enabled
      GTK Randomization.......................... Disabled
      SKC Cache Support.......................... Disabled
      CCKM TSF Tolerance......................... 1000
   Wi-Fi Direct policy configured................ Disabled
--More-- or (q)uit
   EAP-Passthrough............................... Disabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web Authentication Timeout.................... 300
   Web-Passthrough............................... Disabled
   Mac-auth-server............................... 0.0.0.0
   Web-portal-server............................. 0.0.0.0
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   FlexConnect Local Switching................... Enabled
   FlexConnect Central Association............... Disabled
   flexconnect Central Dhcp Flag................. Disabled
   flexconnect nat-pat Flag...................... Disabled
   flexconnect Dns Override Flag................. Disabled
   flexconnect PPPoE pass-through................ Disabled
   flexconnect local-switching IP-source-guar.... Disabled
   FlexConnect Vlan based Central Switching ..... Disabled
   FlexConnect Local Authentication.............. Disabled
   FlexConnect Learn IP Address.................. Enabled
   Client MFP.................................... Optional
   PMF........................................... Disabled
   PMF Association Comeback Time................. 1
--More-- or (q)uit
   PMF SA Query RetryTimeout..................... 200
   Tkip MIC Countermeasure Hold-down Timer....... 60
   Eap-params.................................... Disabled
AVC Visibilty.................................... Disabled
AVC Profile Name................................. None
Flex Avc Profile Name............................ None
Flow Monitor Name................................ None
Split Tunnel Configuration
    Split Tunnel................................. Disabled
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Assisted Roaming Prediction Optimization......... Disabled
802.11k Neighbor List............................ Disabled
802.11k Neighbor List Dual Band.................. Disabled
802.11v Directed Multicast Service............... Disabled
802.11v BSS Max Idle Service..................... Enabled
802.11v BSS Transition Service................... Disabled
802.11v BSS Transition Disassoc Imminent......... Disabled
802.11v BSS Transition Disassoc Timer............ 200
802.11v BSS Transition OpRoam Disassoc Timer..... 40
--More-- or (q)uit
DMS DB is empty
Band Select...................................... Disabled
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
Universal Ap Admin............................... Disabled
 Mobility Anchor List
 WLAN ID     IP Address            Status                             Priority
802.11u........................................ Disabled
MSAP Services.................................. Disabled
Local Policy
Priority  Policy Name
Lync State ...................................... Disabled
Audio QoS Policy................................. Silver
Video QoS Policy................................. Silver
App-Share QoS Policy............................. Silver
--More-- or (q)uit
File Transfer QoS Policy......................... Silver
Thushara
Leo Laohoo
You're saying "client". Are saying there is only ONE wireless client having issues?
So when the 2.4 Ghz of an AP is turned off, the client goes to another AP and joins another 2.4 Ghz?
1.  Is 5.0 Ghz turned on?
2.  What antenna are you using for the 2.4 Ghz and 5.0 Ghz?
Hello Leo,
Multiple clients were facing the issue.
Thushara
1.  Is 5.0 Ghz turned on?  yeah 5GHZ is turned on
2.  What antenna are you using for the 2.4 Ghz and 5.0 Ghz? for both the radios it is internal radio
Thushara
Ok, so pick a wireless client and post the complete output to the command "grep include AP.Name|Radio.Signal.Strength.Indicator|Noise.Ratio".
