cisco wireless control system
Nawshard707
Community Member
we are using cisco wireless control system i need block some MAC address or devices how can i do it
Sandeep Choudhary
You can use Mac Filtering Template from WCS: Step 1 Choose Configure > Controller Template Launch Pad. Step 2 Click MAC Filtering or choose Security > MAC Filtering from the left sidebar menu. The Security > MAC Filtering page appears. Step 3 If you want to add a new template, click Add Template from the Select a command drop-down list, and click Go. To modify an existing template, click the template name. The MAC Filtering template page appears: More info: http://www.cisco.com/c/en/us/td/docs/wireless/wcs/7-0/configuration/guide/WCS70cg/7_0temp.html#wp1095263 Regards Don't forget to rate helpful posts
Yes you can block the specific client using MAC Address filtering option in WCS
This option is avialbe in Configure> Security >MAC Filtering
here you can create new template as per your requirement
Go through below link for detail knowledge.
