Cisco Wireless controller 5508 and Packetfence for web authentication
jborthakur
I want to enable Web Auth with Cisco Wireless controller 5508 (Sw Version8.5.135.0)  for guest users. Packet fence we are using Version 11.2.0.
I have created a guest SSID in CISCO Wireless Controller as GUEST1 and as per the configuration recommended in technical doc trying to configure the same but it is creating some issues.
Here we want to  create a captive portal for guests where they will only have to accept the terms and conditions prior to gaining network access, later we want to use it with guests to register endpoints using their email address. PacketFence sends a PIN code to the guest’s email address.
So kindly help me to achieve the same.
detail setup is attached.
Mark Elsen
 - Check this document : https://www.packetfence.org/doc/PacketFence_Network_Devices_Configuration_Guide.html#_wireless_lan_controller_wlc_web_auth
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
I used this doc only for configuration but its not working.
