Can't ping from wireless devices -IR829
nadeesh.sam
Hi everyone!
I have an IR829 that has two VLANs setup for wireless and wired clients. I can't access any wired vlans devices from the wireless vlan. Please help me diagnose the problem Thank you!
Tests
  • From the router
 I can ping all the devices from the router with different sources.Screenshot 2022-07-19 181340.png
  • From a wireless device [Successfully gets the 172.16.3.4 ip from DHCP]
I can ping both vlan gateways but can't ping the two devices on the VLAN10- WIRED (Weird I know haha )
5 Replies 5
the policy routing prevents traffic between both Vlans. What is the purpose of the policy routing ? In order to get connectivity, first of all make the changes marked in bold. Once you have connectivity, we need to look at the PBR:
Current configuration : 9297 bytes
! No configuration change since last restart
version 15.8
service password-encryption
hostname ir829
boot-start-marker
boot-end-marker
enable secret 5 $1$FdvL$4G/AODmmwE1/Z18RW9b890
aaa new-model
aaa authentication login default local
aaa session-id common
service-module wlan-ap 0 bootimage autonomous
ignition off-timer 900
ignition undervoltage threshold 11 000
no ignition enable
ip dhcp excluded-address 172.16.3.2
ip dhcp pool WIRELESS
network 172.16.3.0 255.255.255.0
default-router 172.16.3.1
dns-server 8.8.8.8 8.8.4.4
ip dhcp pool WIRED
network 172.16.2.0 255.255.255.0
default-router 172.16.2.1
ip dhcp pool CC-Comp
host 172.16.2.50 255.255.255.0
client-identifier ff66.7b93.2a00.0200.00ab.11d6.4942.a591.f597.e8
ip domain name vh.com
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip cef
ipv6 unicast-routing
ipv6 cef
chat-script lte "" "AT!CALL" TIMEOUT 20 "OK"
username admin privilege 15 secret 5 $1$b61O$17XyZ4ikIK7qYzKF16c0H/
redundancy
controller Cellular 0
lte sim fast-switchover enable
crypto ipsec profile IPSEC_PROFILE
set ikev2-profile IKEV2_PROFILE
interface GigabitEthernet0
mac-address 00f9.74a9.395e
ip dhcp client hostname CC-ROUTER
ip address dhcp
ip nat outside
ip virtual-reassembly in
no ip route-cache
interface GigabitEthernet1
switchport access vlan 10
switchport mode access
no ip address
no mop enabled
interface GigabitEthernet2
no ip address
no mop enabled
interface GigabitEthernet3
no ip address
no mop enabled
interface GigabitEthernet4
no ip address
no mop enabled
interface Wlan-GigabitEthernet0
description Internal AP
switchport mode trunk
no ip address
interface GigabitEthernet5
no ip address
shutdown
duplex auto
speed auto
interface Cellular0
ip address negotiated
encapsulation slip
dialer in-band
dialer idle-timeout 0
dialer string lte
dialer-group 1
ipv6 address autoconfig
interface Cellular1
no ip address
encapsulation slip
interface wlan-ap0
ip address 1.1.1.1 255.255.255.255
interface Vlan1
no ip address
shutdown
interface Vlan10
description WIRED
ip address 172.16.2.1 255.255.255.0
ip nat inside
--> no ip policy route-map NAT_WIRED
interface Vlan20
description WIRELESS
ip address 172.16.3.1 255.255.255.0
ip nat inside
--> no ip policy route-map NAT_WIRELESS
interface Async0
no ip address
encapsulation scada
shutdown
interface Async1
no ip address
encapsulation scada
shutdown
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source route-map NAT_WIRED interface Cellular0 overload
ip nat inside source route-map NAT_WIRELESS interface GigabitEthernet0 overload
ip ssh version 2
ip access-list extended LIST_WIRED
deny ip 172.16.3.0 0.0.0.255 any
deny ip 172.16.2.0 0.0.0.255 172.16.11.0 0.0.0.255
permit ip 172.16.2.0 0.0.0.255 any
ip access-list extended LIST_WIRELESS
deny ip 172.16.2.0 0.0.0.255 any
deny ip 172.16.3.0 0.0.0.255 172.16.11.0 0.0.0.255
permit ip 172.16.3.0 0.0.0.255 any
ip sla 1
icmp-echo 172.16.11.1
timeout 10000
ip sla schedule 1 life forever start-time now
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipv6 permit
ipv6 ioam timestamp
route-map NAT_WIRELESS permit 10
match ip address LIST_WIRELESS
set ip next-hop dynamic dhcp
set interface GigabitEthernet0
route-map NAT_WIRED permit 10
match ip address LIST_WIRED
match interface Cellular0
control-plane
line con 0
exec-timeout 0 0
stopbits 1
line 1 2
stopbits 1
line 3
script dialer lte
no exec
transport preferred none
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
line 4
no activation-character
no exec
transport input all
line 8
no exec
line 1/3 1/6
transport output none
stopbits 1
line vty 0 4
transport input ssh
no scheduler max-task-time
ntp server time.google.com
ntp server pool.ntp.org
no iox hdm-enable
iox client enable interface GigabitEthernet5
no iox recovery-enable
end
Current configuration : 2656 bytes
version 15.3
no service pad
hostname ir829-ap
logging rate-limit console 9
enable secret 5 $1$OSYE$3C3yLk/lHhRdyO3zOsiLl0
aaa new-model
no ip source-route
no ip cef
dot11 pause-time 100
dot11 syslog
dot11 vlan-name vlan20 vlan 20
dot11 ssid ABCD-Wifi
vlan 20
authentication open
authentication key-management wpa version 2
guest-mode
wpa-psk ascii 7 04550E090C2E581F5B4A
no ipv6 cef
username admin privilege 15 secret 5 $1$D/Cr$RyL7oPLbeFwgMH6iYEkKF.
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 20 mode ciphers aes-ccm tkip
ssid ABCD-Wifi
antenna gain 0
speed basic-1.0 basic-2.0 basic-5.5 basic-11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.20
encapsulation dot1Q 20
no ip route-cache
bridge-group 20
bridge-group 20 subscriber-loop-control
bridge-group 20 spanning-disabled
bridge-group 20 block-unknown-source
no bridge-group 20 source-learning
no bridge-group 20 unicast-flooding
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
antenna gain 0
peakdetect
no dfs band block
channel dfs
station-role root
bridge-group 1
description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
no ip address
no ip route-cache
bridge-group 1
interface GigabitEthernet0.20
no ip route-cache
bridge-group 20
interface BVI1
mac-address f01d.2d55.85ce
ip address 172.16.3.2 255.255.255.0
no ip route-cache
ip http server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
--> ip route 0.0.0.0 0.0.0.0 172.16.3.1
bridge 1 route ip
bridge 20 route ip
line con 0
privilege level 15
line vty 0 4
transport input all
cns dhcp
end
Hi Georg,
Thanks for pointing me in the right direction. It started working once I made your changes.
I'm hoping to use PBRs to give internet access to the vlans from different interfaces. Vlan10 shoud go to the internet from the Cellular0 interface and Vlan20 should go to the internet through GigabitEthernet 0 interface.
Would you be able to help me set up this as well?
with the changes marked in bold, the PBR should work:
version 15.8
hostname ir829
boot-start-marker
boot-end-marker
aaa new-model
no ignition enable
ip dhcp pool WIRED
ip cef
ipv6 cef
redundancy
ip address dhcp
ip nat outside
no ip route-cache
no ip address
no mop enabled
no ip address
no mop enabled
no ip address
no mop enabled
no ip address
no mop enabled
no ip address
no ip address
shutdown
duplex auto
speed auto
interface Cellular0
encapsulation slip
dialer in-band
dialer string lte
dialer-group 1
interface Cellular1
no ip address
encapsulation slip
interface wlan-ap0
interface Vlan1
no ip address
shutdown
interface Vlan10
description WIRED
ip nat inside
--> ip policy route-map NAT_WIRED
interface Vlan20
ip nat inside
--> ip policy route-map NAT_WIRELESS
interface Async0
no ip address
encapsulation scada
shutdown
interface Async1
no ip address
encapsulation scada
shutdown
no ip http server
ip ssh version 2
--> ip access-list extended LIST_WIRED
--> permit ip 172.16.2.0 0.0.0.255 any
--> ip access-list extended LIST_WIRELESS
--> permit ip 172.16.3.0 0.0.0.255 any
ip sla 1
timeout 10000
ipv6 ioam timestamp
--> route-map NAT_WIRELESS permit 20
--> route-map NAT_WIRED permit 20
control-plane
line con 0
exec-timeout 0 0
stopbits 1
line 1 2
stopbits 1
line 3
script dialer lte
no exec
line 4
no exec
transport input all
line 8
no exec
line 1/3 1/6
stopbits 1
line vty 0 4
transport input ssh
no iox hdm-enable
end
Hi Georg,
I made the change and it seems to retain all the inter VLAN connectivity. I have internet on VLAN20 but VALN10 doesn't have internet now. Here's the test I did to verify.
Show ip route gives me this,
Could you identify any problem? Current configuration is below,
ip dhcp excluded-address 172.16.2.2
dns-server 172.16.3.1
ip dhcp pool WIRED
dns-server 172.16.2.1
ip domain name XXXXXX
ip host cabin.hm.local 172.16.2.50
ip host cabin.hm 172.16.2.50
ip multicast-routing
ip cef
ipv6 cef
license udi pid IR829GW-LTE-LA-ZK9 sn FGL2602L191
redundancy
lte sim data-profile 1 attach-profile 1 slot 0
no lte gps enable
lte modem link-recovery disable
interface Tunnel0
tunnel source GigabitEthernet0
tunnel destination dynamic
tunnel protection ipsec profile IPSEC_PROFILE
ip address dhcp
ip nat outside
no ip route-cache
no ip address
no mop enabled
no ip address
no mop enabled
no ip address
no mop enabled
no ip address
no mop enabled
no ip address
no ip address
shutdown
duplex auto
speed auto
interface Cellular0
ip nat outside
encapsulation slip
load-interval 60
dialer in-band
dialer idle-timeout 300
dialer string lte
dialer-group 1
async mode interactive
routing dynamic
interface Cellular1
no ip address
encapsulation slip
interface wlan-ap0
interface Vlan1
no ip address
shutdown
interface Vlan10
description WIRED
ip nat inside
interface Vlan20
ip nat inside
interface Async0
no ip address
encapsulation scada
shutdown
interface Async1
no ip address
encapsulation scada
shutdown
no ip http server
ip dns server
ip route 0.0.0.0 0.0.0.0 Cellular0
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0 dhcp
ip ssh version 2
ip sla 1
timeout 10000
ipv6 ioam timestamp
match interface GigabitEthernet0
control-plane
line con 0
exec-timeout 0 0
stopbits 1
line 1 2
stopbits 1
line 3
script dialer lte
modem InOut
no exec
rxspeed 150000000
txspeed 50000000
line 4
no exec
transport input all
line 8
no exec
rxspeed 150000000
txspeed 50000000
line 1/3 1/6
stopbits 1
line vty 0 4
transport input ssh
no iox hdm-enable
end
I think you have to add the line marked in bold:
--> set interface Cellular0
